Grinding/sharpening
Silicon Carbide Grinding Stone (85602)
Thin, small grinding stone. For grinding non-ferrous materials like stone
£7.00*
RRP incl. VAT
What can you do with it?
For sharpening, deburring and general purpose grinding. Typical uses include removal of stilt marks and excess glaze, sharp edges on tiles and engraving on glass.
These grinding stones are tougher than aluminum oxide points, these are made especially for use on hard materials such as glass and ceramics.
How to use?
Use the side of the accessory for the best finish at an angle.
Materials to use on:
To grind and etch stone, glass, ceramics, porcelain and non-ferrous metals
Recommended speeds (RPM):
Ceramic: 35.000
Glass: 35.000
Stone: 10.000 - 15.000
Shell: 10.000 - 15.000
Glass: 35.000
Example of usage
Technical details for Silicon Carbide Grinding Stone (85602)
Aerated Concrete
Concrete
Drywall/Plasterboard
Brass
Copper
Soft Metal
Porcelain
Brick
Marble
Granite
Ceramic
Glass
Technical specifications
Shank diameter
Working diameter
10,3 mm
Accessory length
10,0 mm
10,0 mm
Height
Maximum RPM
20.000 1/min
Package Contents
3 pieces
Suitable Dremel devices
Multi-Tools
26155602JA
8710364044979
Similar Accessories (3)
Delivery details: Silicon Carbide Grinding Stone (85602)
Product box length, 2 cm
Product box height, 10 cm
Product box width, 5 cm
26155602JA
8710364044979
8710364044979
