Carving Engraving
Tungsten Carbide Cutter spear tip 3,2 mm (9910)
Tungsten Carbide Cutter spear tip 3,2 mm Tungsten Carbide Cutter spear tip 3,2 mm Tungsten Carbide Cutter spear tip 3,2 mm
Cone shaped point bit, one of Dremel's toughest engraving/carving bits.
£11.00* RRP incl. VAT
Example of usage
Technical details for Tungsten Carbide Cutter spear tip 3,2 mm (9910)
  • Carbon Carbon
  • Leather Leather
  • Rubber Rubber
  • Drywall/Plasterboard Drywall/Plasterboard
  • Brick Brick
  • Brass Brass
  • Soft Metal Soft Metal
  • Softwood Softwood
  • Ceramic Ceramic
  • Hardwood Hardwood
  • Aluminium Aluminium
  • Cast iron Cast iron
  • Plastic Plastic
Technical specifications
Shank diameter
Working diameter
Accessory length
Height
Maximum RPM
30.000 1/min
Package Contents
1 piece
Variations
Delivery details: Tungsten Carbide Cutter spear tip 3,2 mm (9910)
Product box length, 5 cm
Product box height, 10 cm
Product box width, 1.3 cm
2615991032
8710364008674
