Sanding
Flap wheel 9,5 mm (502)
Flap wheel 9,5 mm
Flap wheel 9,5 mm
Flap wheel 9,5 mm Flap wheel 9,5 mm
Largest flap wheel (grit P80). Works well for (gentle) finish removal
£7.70* RRP incl. VAT
What can you do with it?
Flap wheels are great for finish removal and light material clean up because they are more forgiving than sanding bands. They won’t bite into the material as quickly. They also tend to run a little cooler because of the flaps – so they are less likely to put any burn into the material. Grind and polish flat or contoured surfaces. Most effective when used as a finishing sander after heavier surface sanding and material removal is completed. Comes in fine and coarse grades
How to use?
Flap wheels are most effective when the edge is flat against the work piece, allowing for the most abrasion to take place.
Materials to use on and recommended speed
Aluminium 30-35000
Brass 30-35000
Copper 30-35000
Hardwood 30000
Plastic 10000
Softwood 35000
Steel 35000
Example of usage
Technical details for Flap wheel 9,5 mm (502)
  • Plywood Plywood
  • Softwood Softwood
  • Chipboard Chipboard
  • Hardwood Hardwood
  • Soft Metal Soft Metal
  • Brass Brass
  • Gold Gold
  • Aluminium Aluminium
  • Silver Silver
  • Copper Copper
  • Rubber Rubber
  • Plastic Plastic
  • Plexiglass Plexiglass
Technical specifications
Shank diameter
Working diameter
28,6 mm
Working height
9,5 mm
Accessory length
50,0 mm
Grit
80
30,0 mm
Maximum RPM
30,0
Height
44,0
Package Contents
1 piece
Variations
Delivery details: Flap wheel 9,5 mm (502)
Product box length, 2.3 cm
Product box height, 10 cm
Product box width, 5 cm
2615050232
8710364015252
