Sanding
EZ SpeedClic accessories
DREMEL® EZ SpeedClic: Sanding Discs (SC411) 6 pieces
Sanding
Easy to change disks for flat and edge sanding of e.g. wood
  • Designed with the patented EZ Speedclic™ system making accessory changes 6X faster compared to the regular Dremel sanding discs
  • Can be used to sand / smooth softer materials like hardwood, softwood, plastic, fiberglass.
  • Smooth or shape wood, remove.
See all variations
6.4 GBP
Sandwich material
Steel-general
Metal pipes
Veneered woods
Plastic
Brass
Copper
Softwood
Soft Metal
Fiberboard
Laminates
Plywood
Hardwood
Chipboard
What can you do with it?
Common uses for the Dremel sanding disc include smoothing and shaping wood or removing paint. is great for (smooth) flat and edge sanding of soft materials such as wood and fiberglass Dremel sanding discs have a finer grit than Dremel sanding bands. Also used for rust removal The lower the grit, the more material removal. The SC411 (grit: 60) and SC 413 (grit: 240) are from the Dremel Exclusive EZ Speedclic family. This makes accessory changes easy as PULL - TWIST - RELEASE.
How to use?
Use with SC402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel (EZ SpeedClic mandrel SC402 sold separately). These discs are best used with the Dremel tool facing towards the work piece, and are flexible to accommodate for any curves on the project. We recommend using mainly the center of the disc for maximum results.
Sanding discs will wear out and are replaceable by removing the mandrel.
Materials to use on
These disks can be used to sand / smooth softer materials like hardwood, softwood, plastic, fiberglass, aluminum but also for rust removal of metal types, like steel. Can shape rubber surfaces
Recommended speed
Hardwood 10-35000 Softwood 10-35000 Aluminium 35000 Brass 35000 Copper 25-35000 Plastic 10-20000
Shank diameter
Working diameter
Grit
Package contents
Price
2615S411JA
3.2 mm
30.0 mm
6 pieces
£6.30*
  • Easy to change disks for flat and edge sanding of e.g. wood
2615S402JB
1 piece
£14.50*
EZ SpeedClic Mandrel (SC402)
2615S413JA
3.2 mm
30.0 mm
6 pieces
£6.30*
DREMEL® EZ SpeedClic: Sanding Discs (SC413) 6 pieces
2615PG10AC
1 piece
£13.00*
DREMEL® EZ SpeedClic: Pet Nail Grooming Discs (SD60-PGK)
F1300000ZZ
1 piece
£12.00*
DREMEL® EZ SpeedClic: Pet Nail Grooming Discs (SD60-PGK-1)
Shank diameter
3.2 mm
Working diameter
30.0 mm
Sandpaper with Silicon Carbide Abrasive
Shape
Disc
Mandrel use
Use with EZ402 EZ Lock™/SC402 EZ SpeedClic Mandrel
Grit
60
32.0 mm
32.0
Height
3.0
6
6
Suitable Dremel devices
Retired Products
Multi-Tools
DREMEL® Pet Nail Grooming Kit (7020-PGK)
8710364060917
2615S411JA
Dremel accessory SC411_EZ SpeedClic SANDING DISC
Delivery details
  • Product box length, 1.6 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
  • Gross weight, 0.01 kg
6.4 GBP
